my 01 500 4x4 wont start
Old Jan 3, 2012 | 12:52 PM
Sylvethter's Avatar
Default my 01 500 4x4 wont start
ok, here we go. was out wheeling with my roommate yesterday and for starters, the part of the housing on the front diff where the engage/disengage rod attaches broke apart. so the machine lost its 4x4 capabilities. we decided to keep riding anyways (im now regretting) and the front left tire got stuck in a small hole in the ice. using my 650 i decided to give him a light bump in the rear end and as soon as i did, the 500 died. i suspect that i crossed the exposed wires coming out the broken taillight bulb. but what i fried i have no idea. when the key is turned on the fan kicks on, but none of the lights on the handlebars light up (manual trans by the way) and the start button does not do anything. i tried just jumping the starter relay, but all it does is crank. it wont fire. any ideas on what i cooked? a wire? the cdi? please help.
Old Jan 4, 2012 | 06:19 PM
emt301660's Avatar
Check the ignition fues, Make sure that didnt blow, Check spark, That would be the first step
Old Jan 5, 2012 | 03:27 AM
Sylvethter's Avatar
already did check all the fuses, heck my first thought was that it was the starter relay fuse, but all the fuses are fine.
Old Jan 8, 2012 | 01:28 AM
weez440's Avatar
the bulb would have no effect on the ignition system. maybe you should start by pulling the plug and seeing if it has spark, if it does then it is a fuel problem. if it has no spark then it is a electrical problem. you would be suprised how coincidental things happen. if you suspect the cdi then get your nose down there and smell the cdi cause i had it happen once with an aftermarket cdi and you could easily smell it was burnt. where the harness plugs in.
Old Jan 8, 2012 | 08:45 AM
Sylvethter's Avatar
ok, well ill give that a try, but what do i do about the dash lights for the gear indicators and such not lighting up when i turn the key on?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
