400 wont run
Old Jan 15, 2012 | 06:09 PM
dcmrn1959's Avatar
Default 400 wont run
Have a 2007 400 fis that has sat for about a year??? i put a new battery in it. tried to start it, would start if i primed it run a few seconds then quit. i cleaned out the bottom of the carb and opened up a clogged jet. it will start run a few seconds then die. any ideas or advice??? appreciate the help. Dan
Old Jan 16, 2012 | 02:51 PM
woodsidewarrior's Avatar
It still has a dirty carb. All of the jets need to be removed and cleaned or sometimes replaced. Also make sure that the fuel tank is clean and all of the passages of the carb are clean. Even a small piece of dirt can clog a jet or passage
Old Jan 16, 2012 | 03:21 PM
dcmrn1959's Avatar
Thank you, I will clean it again and do a better job lol
Old Jan 16, 2012 | 05:15 PM
dcmrn1959's Avatar
That fixed it. Found another jet that was clogged. Thanks again.
