Differential fluid change
Old Jan 28, 2013 | 03:22 PM
s16's Avatar
s16
Default Differential fluid change
What is the easiest way to change diff fluid in front and rear I have a 03 400 auto fis. I also have a plow mounting plate attached to the bottom of the atv. Looks like a pretty tight fit to get to the drain plug.
Any suggestions to make this easier.
Old Jan 29, 2013 | 06:40 AM
TLC's Avatar
TLC
Here is a cheat I use on my snowmobile chain case. it sucks the old chain case oil out without having to split the chain case.
It might leave 10% of the old stuff behind but the new 90% mixed with it should not make it matter.
Old Jan 29, 2013 | 05:40 PM
swampyjunior's Avatar
If you can get the ATV up off the frount a ways on jack stands you can use a 1-1/4 inch hole saw to drill a proper hole in your skid plate to get the fluid to not drain onto the skid plate.
As TLC said you can use a fluid transfer pump too. Harbor Freight sells a cheap one for like $5. The fill plug is MUCH larger than the drain plug anyway and far easier to get at.
I change mine by removing the skid plate but with your plow mount that would take a little more effort. Good thing you don't have to change it very often!
Swampy
MaasaiMomma
Mar 25, 2021 11:24 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
