99 arctic cat 500 4x4 Valve clearance
Which do I set the valves at 0.17 or 0.22 mm
All that means is if final adjustment clearance between the rocker arm and valve stem is between 0.17 mm(tightest point allowed) and 0.22 mm (largest amount allowed) then you're fine.
thanks for for the help
georgep
Technical and How-To Articles
Aug 27, 2009 12:11 PM
Newfieguy
Jan 20, 2007 06:09 PM
