REV Limiter?????
give you the sum up version ANYONE I am stumped
2104 arctic cat 500xt 900+ miles on it after I blew the belt and replaced the primary plate, weights, spacers, and new belt all torqued to specs I took bike for a ride all went well up to 50 + mph to seat the belt then brought it home ,the next day I snowed plowed fine with it , rev limiter working like it shld in reverse , then took plow off to ride w the boys and cannot get over 20 mph in high , I AM CONFUSED not sure what to ck any help out there would be awesome thanks in advance Mike |
Check that the diodes are all installed correctly. If one accidentally gets put in backwards, that can happen. Rev limiter hits at 7250 rpms on my AC 700. The old Suzuki design 500's would actually turn over 8,000. The new 443 Kymco motors, have no clue.
Still confused
[QUOTE=hydrex;3381967]Check that the diodes are all installed correctly. If one accidentally gets put in backwards, that can happen. Rev limiter hits at 7250 rpms on my AC 700. The old Suzuki design 500's would actually turn over 8,000. The new 443 Kymco motors, have no clue.[/QU
Hey hydrexbthanx for trying to help me when I tell ya diodes and or fuses were never touched the atv is barely riden that is why I am stumped at what the heck I should look for next ...,, besides a fire sale sign MikeMike |
So, it's only in high? It should do 30 or so in low range. See if you can download a wiring diagram from Country Cat. There has to be a logical explanation. Check wire connections at cdi unit. Heck, I've even heard similar symptoms from bad gas, but yours sounds possessed! I have a 2014 TRV 700 with 1500 miles, which is quite similar. Closest to that , was when my 700 Diesel got some water in the tank and the fuel filter froze up.
rev limiter
Hydrex I do have a CD on all the tech specs on the atv , Yes when I plowed last wk with it it never happened and ran fine, even the rev limiter worked as should In reverse
then I took it up in the field after taking plow off I could not get over 20mph I did buy a new belt from high lifter wondering if it could be wrong and causing the problem, I did see the belt seat on the primary all the weights are new and the plate is new including the spacers all torqued to spec wondering if the atv is just having another problem (REV LIMITER) where do you think I should look next any help would be great Thanks Mike |
Let's confirm it's not the belt slipping. Does rev limiter still work in reverse? Push the button until you get RPM'S. My guess, if it's rev limiter it will hit a fixed rpm, like 3,000 or 4,000, etc. If it's reving up high like 5,000-6,000 then it's the belt. I wish you were near me, I have an incredible ATV mechanic that works on all brands.All the dealers call him for really tough problems. Plus he only charges $50/hr. If we can't figure this out, I can call him after the holiday, he's a snowmobiler too. Anyway, Happy New Year. Maybe put the plow back on.... is it red like Christine?
reply
Hydrex that make a whole lot of scense, when I put the belt on it looked kinda big cause it was new I rode it slow and it ran fine gradually increasing speed to 45/50 I figured the belt was seating properly, now that I had my son and I took a rip we almost full throttled it and that would cause the belt to SLIP in turn would activate the throttle limiter................I believe you solved it now my question is how do I seat the belt better I am still riding it w plow but its at low speed, again it is the correct belt from HIGH LIFTER
, should I buy another belt from someone else or is there a process to properly seat it? thanks a lot Bud Mike |
go back to OEM belts they seem to work the best. The high lifter belt is still made by dayco and finding some spec's i would say its the wrong belt. Luckily its only a 15min job to replace a belt on a 500
[QUOTE=Zrock;3382215]go back to OEM belts they seem to work the best. The high lifter belt is still made by dayco and finding some spec's i would say its the wrong belt. Luckily its only a 15min job to replace a belt on a 500[/QUOT
Thanx Zrock I did order a new belt waiting on it to arrive ,,,,more dam money on this atv |
Ya own is not cheap paid $280 for mine at the dealer. Only aftermarket belt I have heard that is any good is the gates carbon fiber. But my oem went 8000km with some hard snow riding where I thought I had cooked it. But measuring new and old their was basically no difference in width
