2000 Arctic Cat 500 speed issue
Old Sep 24, 2020 | 12:35 PM
bearman01's Avatar
Cool 2000 Arctic Cat 500 speed issue
I have had this ATV for about 12 years and it always ran good with no problems. The carb started leaking so I cleaned it and put in a new carb kit. Now it gets up to 20 mph with the first half throttle and only goes to 24 mph with full throttle and that takes up to 1/4 mile to accomplish. I've tried adjusting the needle valve from 1 1/2 - 2 1/2 turns out but it didn't help. Since the old jets were clean I put them back in and tried that but it made no difference. Can anyone offer a suggestion as to what to try. I'm not sure if this problem is related to the carb cleaning or not. Thanks
Old Sep 29, 2020 | 10:28 AM
Alex G.'s Avatar
Well if it ran good before you cleaned the carb and after your having problems.... then it just might be related..
I'd redo the carb... are the jets the same size? and if not did you put them back in the correct locations?
Old Sep 29, 2020 | 11:58 AM
bearman01's Avatar
Thanks for the response. Yes the jets are the correct size and location. I'll redo the cleaning process again.
Old Sep 30, 2020 | 08:04 AM
fixitup's Avatar
Make sure the boots are not sucking air.
Old Oct 2, 2020 | 07:26 PM
bearman01's Avatar
Problem solved. I bought one of those longer air/fuel mixture screws so I could fine tune the setting better. It's only open about 1 turn now but it works fine.
Thanks for the comments.
Malcolm Nye
Jan 20, 2021 06:55 PM
kjp
Apr 24, 2011 12:19 AM
kbrown
Jul 19, 2010 12:07 AM
FireNHunt
Dec 7, 2008 01:54 AM
