Oil in crankcase on Arctic Cat 300
Old Mar 12, 2021 | 10:06 AM
mike2009's Avatar
Default Oil in crankcase on Arctic Cat 300
Hello, I have an Arctic Cat 300 and went to go start it and it made a weird noise. I found out that the crankcase is filled with gas. Everything I read says the needle and seat would cause that. After I replace those I understand I need to change the oil a couple times to flush out all the gas. This may be a stupid question but do I need the change the filter both times also? Also would trying to crank the engine while it is full of gas cause any damage? Thank you for any help.
Rubymass090
Sep 16, 2018 07:45 AM
backhoelover
Jun 26, 2015 12:21 PM
phawesII
Jan 9, 2014 05:01 PM
