Reasonably Priced Oil Filters
Old Jan 24, 2002 | 06:06 PM
NewCatMan's Avatar
I finished some research where you don't have to pay $12 for an oil filter for the 2001-2002 500cc Cats. These filters will work and can be obtained from your local AutoZone from $4-$6.
FRAM 6018
Purolator 16818
WIX 51359
STP SMO-18
Old Jan 24, 2002 | 09:40 PM
chunkyboy's Avatar
HEY DUDE, dont forget napa 5.28 pn 1359 , My new 400i has one already , AND ITS AGAINST THE LAW TO VOID A WARRANTY BECAUSE YOU DONT USE A FACTORY OIL FILTER, read that at advance auto last year , so dont let that make your dision for you . CHUNKY
Old Jan 25, 2002 | 09:02 AM
NewCatMan's Avatar
So you have to use factory oil and factory air and factory gas. I don't buy it. Every car owner in America is voiding warantees.
Thanks for Napa. The list is complete. We can buy 3 filters for the price factories one. K@N makes a filter also but it too is listed for $12.
Now I'm working on platinum plugs so far no one makes one.
Old Jan 25, 2002 | 11:45 AM
ttaylor's Avatar
If I had known that I could have saved me money on the first oil change. I let the dealer do it because it was still under warranty. I thought that if I did it myself and used a Fram or other oil filter that it would void my warranty. Now I change the oil myself and use the Fram Filters and quaker state semi synthetic oil.
Thanks for the info
Old Jan 25, 2002 | 07:42 PM
Redbaron's Avatar
Can anyone tell me if the Suzuki Vinson uses the same oil filter?
Old Jan 27, 2002 | 09:28 AM
NewCatMan's Avatar
I would think that it would being it's the same engine. I can't verify it through the parts books yet because the Vinson is not yet listed.
I'm working on a $4.50 jet kit. K@N offers a $70 jet kit which is nothing more than 6 jets and an adjustable needle. K@N's website gives you the instructions which is nothing more than determining your elevation and installing the proper jet and clip position. This is claimed to give you a 5% net gain and better overall response.
The manufactures jet these things for an average of all elevation thus giving K@N something to enhance performance. The extra jets provide for a pipe and aircleaner upgrade. The jet size is given on the instructions for this mod too.
I'm trying to figure out what the stock jet and needle position of a 2002 500 is.
Old Jan 27, 2002 | 09:35 PM
mudcat47537's Avatar
The Vinson and Q-Master should use the same oil filter, I know the Q-Master does.
As far as the stock jet sizes. Here's what the manual says.
Keihin CVK34
Main jet: 148
Slow jet: 38
Jet needle: N601
Needle Jet: 6.0/4.0
Starter Jet: 102
Pilot screw: 2.25 turns
You can get the jets from your dealer, or other cycle shop. I've heard the K&N jets are drilled different and a K&N 150 jet won't be the same as a 150 Keihin jet. Also heard that the needle jet isn't adjustable on this carb. It doesn't show it being adjustable in the book.
Old Jan 27, 2002 | 10:03 PM
IowaBob's Avatar
Do the 400s take the same filter as the 500s?
Bob
Old Jan 28, 2002 | 08:57 AM
NewCatMan's Avatar
Thank you MudCat! That's all I need to know. I've heard the jets are different and needed too to know about the needle. I can purchase an adjustable needle from a reputable carb company and match the height with stock and raise or lower the adjustable needle a washer thickness. As for jetting. I believe the factoy jets these things to service 3000 to 6000ft. The unit will basically run any where in the U.S. I live at an elevation of 1500. Which should require a leaner jet.
K@N suggest using a Dynojet #132 below 3000 ft
#128 3000 to 6000 ft
#124 6000 ft and above
With header: #136 below 3000 ft
#132 3000 to 6000 ft
#128 6000 ft and above
Pilot Screw, 3 turns out
Needle, below 5000 ft, groove #4, above 5000 groove #3. (from top)
What do others think about this?
IowaBob, the catalogs show the same filter part # for 1998-2002 400, 454, 500, AC's
Old Jan 28, 2002 | 10:08 AM
I live at 600 feet and all the quads that I've had, seem to be a little on the rich side.
I don't know much about the changes in elevation affecting jetting. I think that the higher you go the leaner your jetting will get or you need to install a bigger jet to make your mixture richer. Is this correct? My thinking seems to be backward to the instructions from K&N. Maybe you high ground dwellers can help me out? I know how to check the plug to get it correct, but not sure of the affects of elevation on jetting.
The oil filter is the same on the 375 too.
