Hot Grips & thumbwarmer on '03 400i
Old Nov 24, 2002 | 12:17 AM
rws's Avatar
rws
Default Hot Grips & thumbwarmer on '03 400i
No more cold hands & thumb. Had to cut part of the stock thumb throttle off and fabricate a new lever to get it lower for clearance for the wiring...epoxied the Unlimited Parts thumbwarmer on with J&B Weld. Used the internal wire style Hot Grips so had to drill holes in the handlebar weights for the wires to go through. Installed a relay so there is power only when the key is on and mounted two toggle switches up on the consol to control high and low temp.
Hot Grips & thumbwarmer picture
Old Nov 26, 2002 | 09:57 PM
lucien's Avatar
Hi.i too wanted to put a thumb and hand warmer on my 250 but didn't know how to set it up on the trottle.Is the trottle solid or hollow?? can i gouge it from behind with a grinder to put the element inside?? Here at Royal Distributing they sell 2 one is wide and one is narrow for small trottle.What should i get. TX
Old Nov 27, 2002 | 10:57 AM
rws's Avatar
rws
lucien
Not sure what you mean by "solid or hollow throttle". Handlebars are generally hollow but may have metal weights pressed or welded in....in my case I drilled 1/4" holes through the weights for the wires, as I preferred to use hidden wire Hot Grips. External wire grips are also available...see following site.
Hot Grips website
There are two different styles of thumb warmers....one is attached to the back of throttle and the other is attached to the front. I chose the front mounted style.
Parts Unlimited Thumb Warmer
If you do a search on www.google.com using "hand warmers" or "thumb warmers" you will find more information.
Old Nov 28, 2002 | 10:05 PM
Fango's Avatar
I recently installed the hot grips on my machine also. I don't know why I waited so long...???!!![img]i/expressions/face-icon-small-confused.gif[/img]... to add this simple upgrade. For all you Northern riders, this is the ticket![img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 28, 2002 | 10:07 PM
Fango's Avatar
Can't wait for Ice Fishing season!!!![img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img] Not long now!!
Old Dec 4, 2002 | 02:57 PM
Bucksnot's Avatar
I put on the 'Moose' hand and thumb warmers. I really like them. Nice rubber grips. really easy job, pretty good directions. I used only one switch and piggy-backed the hand and thumb warmer.
black_thunder
Sep 7, 2015 01:24 AM
erntee61
Aug 9, 2015 02:54 PM
Stirling
Aug 9, 2015 01:49 PM
Scottma518
Jul 10, 2015 12:42 AM
ScoobyDFW
Feb 3, 2000 11:58 PM
