annoying vibrating
Old Apr 21, 2000 | 12:21 PM
Tedcat300's Avatar
I have an ac 300 2x4. I have notices that in lower gears at low rpms the atv rattles and vibrates alot. What could cause this?
Old Apr 21, 2000 | 02:50 PM
rab's Avatar
rab
I have a 300 4x4, I've tracked down most of my rattling to be the plastic around the tailight area, where the rack mounts are. Just one of those things you have to ignore I guess.
Old Apr 21, 2000 | 08:50 PM
vtCatamount's Avatar
I have a 500 auto, mostly get a "buzz" from the plastic just below the gas tank and only at a certain rpm while going slow. I've learned to ignore it or change rpms slightly.
Old Apr 21, 2000 | 09:35 PM
sxr6's Avatar
My 300 4X4 would rattle the exhaust pipe heat shield, sounded like it was in the motor until you hold it.
Old Apr 21, 2000 | 09:44 PM
minehunter's Avatar
On the 500, the cover over the radiator cap will vibrate and seem like the plastic over gas tank. Put a piece of foam under the cover and I think your vibration noise will go away.
Santa
Sep 26, 2019 12:56 PM
Dabears1983
Jun 23, 2015 04:59 AM
87r
Feb 25, 2001 12:48 PM
ScoobyDFW
Apr 24, 2000 09:09 PM
Hank
Nov 9, 1999 06:51 PM
