GOING IN THE MUD
Old Mar 24, 2003 | 10:19 AM
ourcat's Avatar
Default GOING IN THE MUD
YESTERDAY I POSTED AN AD 4 MUD RIDING ALL I WANT 2 KNOW IS THIS BEST ACHIEVED AT A HIGH OR LOW SPEED . 2002 300 4X4 THANKS
Old Mar 24, 2003 | 11:11 AM
Olddirtybastard's Avatar
It all depends on the type of mud. If you need momentum hit it in 2nd gear and shift down to 1st if needed. Its easier to shift down than to upshift in the mud.
Old Mar 24, 2003 | 10:57 PM
Cat500i's Avatar
There are too many variable to be a cut and dry answer. If your running stock tires you will want to keep the wheel spin and speed up a bit.
Old Mar 25, 2003 | 09:28 AM
sxr6's Avatar
With my 300 low range 2nd & 1st worked well, With the diff locked & larger tires I now find a few times I need super low to turn the tires, every situation is diff.
