front tires
Old Apr 3, 2003 | 09:42 PM
mudblaster's Avatar
Default front tires
i see allot of pic of guys with 12" tires on the front how does it steer and handle when yuor just rideing
Old Apr 5, 2003 | 12:15 AM
CatKrazy's Avatar
Default front tires
Its a little stiff but after a while you dont realize it. Going to 12s all the way around will only help you!!!!Big Difference
Old Apr 5, 2003 | 12:21 AM
Cat500i's Avatar
Default front tires
Trying out the new 10.50's up front this weekend.
Old Apr 5, 2003 | 04:42 AM
mudblaster's Avatar
Default front tires
i have 10's on the front of mine and i find there vary direct i turn it and it go's where i point it i was thinking of buying 12's when i got them but i didnt think thay would fit my stock rim's and i was already in the dog house for buying the tire's. so i didnt want to push it with new rims also
Old Apr 8, 2003 | 04:54 AM
mudblaster's Avatar
Default front tires
tryed out the new gators in the mud today and thy were awsom it was at least a foot pure river mud my buddyon his forman said go for it i'll pull you out so i went for it i blasted rite through it aprox 50 feet in socond then i turn around and went the whole langth of mybe 100 feet and then told my buddy on his brand new honda rubicon to try. this is his first time trying anything on a atv and he tryed to go through my rutts instead of makeing his own and he got stuck, so me and my other bud helped him out and he tryed again ang got through the forman and the rubicon did ok but mine it never even bogged in 2nd going through the gators are sweet i cant wait to find some more stuff to play on. ps i'll have some new pic in a few days check them out
Old Apr 8, 2003 | 06:53 PM
Turfguy's Avatar
Default front tires
Mudblaster,
Saw that you have the 3" wheel well extensions. Are they easy to insall. Ordered mine today. Should be here before the weekend ride with my buddy and his honda. The biggest advantage he has over me, is that he doesn't get muddy as all hell. I am filthy, and he is still clean. Wondering also if they work. I use mine a lot for hunting and the mud flies up and hits my equipment all the time. Thanks for any info possible.
Old Apr 9, 2003 | 12:06 AM
mudblaster's Avatar
Default front tires
yes thay are very easy to install bu you need a special rivet gun to put them on because thay come with those plastic rivets so thay will brake in sted of ripping off, but your dealer will have one just borrow theres for an hour or so, also make sure you drill the holes in the right spot ore thay will have some small gaps
Old Apr 17, 2003 | 02:06 PM
mudblaster's Avatar
Default front tires
hay turfguy did you get your fender extentions yet and if so have you put them on yet and what do you think of them.
Old Apr 17, 2003 | 03:12 PM
Turfguy's Avatar
Default front tires
They said they were on back order till the middle of MAY last week. I guess they really didn't know because they called and they came in yesturday. I havn't picked up yet been to busy with MSU school work. Probably won't be able to get them and try them untill next week. I got the ones for the rear as well. It likes you only got the ones for the front from your pics. I could be mistaken. Its the same part number for both, found that a bit intresting. I will let youo know when I put them on though.
Thanks Tim
Old Apr 17, 2003 | 03:14 PM
Turfguy's Avatar
Default front tires
After I get these mudflaps I need to get bigger tires. These stock DUNLOPS suck. I hate getting stuck in something that i shouldn't. Have to wait till I get the roof on my house though.
