esr 380 motor kit
Old May 21, 2003 | 03:22 AM
Vision's Avatar
Default esr 380 motor kit
a buddy of mine just sent his bottom end off to eddie sanders to get this kit ,said it claims around 80hp his set up will be for dragin only .motor is going to be in his atc 250r frame. has anyone seen one of these motors in action? and how do you think a good runnig shee thats ported will do against it.
Old May 21, 2003 | 05:50 PM
dragracer789's Avatar
it will beat your shee
Old May 22, 2003 | 02:39 AM
Vision's Avatar
dragracer789,
well thats kinda what i was thinking,i cant wait till it gets back to take a ride on that thing!
Old May 23, 2003 | 02:14 AM
cheesedog's Avatar
i run a ESR 330 on my trik and it is very hard to keep the front down [img]i/expressions/face-icon-small-smile.gif[/img] i clocked my 330 at 82MPH with 14/39 gearing on it . i aslo have a 350 on my quad, but a 380 on a trik watch out that thing should rip!
Old May 24, 2003 | 10:17 PM
kimmer250r's Avatar
Hey guys,
I currently have a esr 310 kit on my 86 R, but think something is wrong with the carb. I have tried every main jet from 160 to 190 in my 39 pwk, but can't get any power in my midrange or topend. This thing has great low range, but no pull or powerband. It just sputters mid to highend. Any ideas??
Old May 25, 2003 | 12:09 PM
atc86r's Avatar
what gap you running?
Old May 26, 2003 | 03:46 AM
cheesedog's Avatar
i has the very same problem tried jetting ,plug gap, and new air filter only to find out i had a bad reed? are your reeds good?
Old May 26, 2003 | 07:15 PM
kimmer250r's Avatar
I'm pretty sure my reeds are good, they are about 1 season old. I did only measure 11.5 volts at the lights and its suppose to be 13.5-14.5 volts. Maybe it is a stator problem, I don't know. The stator ohmed out at 115 which the book says 50-200 is good.
Old Jun 8, 2003 | 03:29 AM
Sm0k3d's Avatar
my neihbor has a niks 310 fully drag port on pump gas w/ 10 paddle ultra lights and can easily beat a ported banshee. When we were at florence, oregon the only thing he got beat by was like a 520 banshee up comp hill.
Right now he's putting his stock 250 jug back on that has a full drag port on alky which should pull even harder than his 310 on pump and he is going to lengthin it +10 cause right now he can't launch without the front end pulling up.
Old Jun 12, 2003 | 05:51 PM
344PV's Avatar
I've seen esr 370's in atc's run they will eat up most ported piped banshee's. My 86 atc with a 344 pv eats them up no prob. is the 80 hp esr is claiming on alcohol.
