honda 200 atc smoking?
Old Aug 5, 2003 | 10:23 AM
bigred250es's Avatar
Default honda 200 atc smoking?
hey why does my 1983 honda 200 atc smoke after i replaced the piston ring, and i put new valve stem seals in it to and the valve guides aint cracked either? Could my cylinder be worn out or what? Any ideas i tried all i kno of to do.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 5, 2003 | 02:42 PM
dork's Avatar
did you hone the cylinder when you put in the rings?
Old Aug 5, 2003 | 03:02 PM
was i suposed to? how do i hone the cylinder and what does it do?
Old Aug 5, 2003 | 03:41 PM
dork's Avatar
if you don't do something to break the glaze on the cylinder, like honing for example, the new rings won't seal properly. honing removes a small amount of material from the cylinder to allow the new rings to seal. you might want to take the cylinder to a shop with a dial bore gauge so they can measure the bore. chances are it may need to be bored and honing won't solve your problem.
Old Aug 5, 2003 | 11:57 PM
well another guy toldme that i could just keep running it and the rings would seat them selves over time?right or wrong and why?
Old Aug 25, 2003 | 11:16 PM
Lameduck's Avatar
You should have honed it Dude!!!
Old Aug 26, 2003 | 04:42 PM
well what do i need to hone the cylinder and how do i do it???????????????????????????????????????????????? ?????????????????????????????
Old Jan 10, 2004 | 09:42 PM
loveotride123456789's Avatar
did you put to much oil in it it smokes if it has too much oil in it
Old Jan 10, 2004 | 11:17 PM
dragracer789's Avatar
Honeing is pritty much roughing the cylinder sleeve so when the sleeve and rings break in they break in together so it seals. You can bring it to your closest shop for that. Its real easy. You could do it your slef if you had one.
Old Jan 12, 2004 | 08:50 PM
huskerjim's Avatar
you can try this you can hone it yourself...first take the top off again go down to your local auto parts store buy a hone kit tool for a brake cylinder it would work for this size cylinder wall just scuff it up and put it back together put a little I mean just a little transmission fluid in your gas like a two stroke run a tank ful and hopefully it will cure your smoke problem and when finished replace plug. happy riding...let me know how your ride goes
