350x vs 250r
Old Dec 24, 2003 | 03:47 AM
pinkelephant's Avatar
Default 350x vs 250r
i read somewhere that a 250R will beat the 350X outright, but if the 250R rider was to miss his shift te 350X would have it
Old Dec 26, 2003 | 12:26 AM
KaRzY5150's Avatar
the 250r is faster then a 350x. top speed its all in gearing, but the 250r is still faster then a 350x.
Old Jan 1, 2004 | 07:04 PM
feL0n's Avatar
250r
Old Jan 1, 2004 | 09:29 PM
ThrashAndCrash's Avatar
Top speed depends on gearing, But engine wise the 250r raps up EXTREMLEY quick and will kill the 350x
Old Jan 4, 2004 | 08:20 PM
  #15
AirManCam's Avatar
Originally posted by: 85ATC350X
In 1985 when the 350x was first in the magazines it went 72.2 mph. The 250r i would say is about 80-85 mph, i own both and the 250r is way faster in all aspects.
Well I hope you guys know the 250r isnt as fast as you guys think. My 86 350x used to go 75 when it was stock minus the 20" tires.Stock=22".The 250r may be able to hit 80 stock give or take a couple mphs. The 350x may get the whole shot depends on the rider then after about 2nd gear the 250r has it. this is stock for stock.
Old Jan 7, 2004 | 05:55 PM
  #16
oldrguy's Avatar
The since discontinued 3 Wheeling Magazine, don't know which issue, clocked the R at 76 mph. That is the fastest "stock" top speed that I have ever seen for it.
One thing to keep in mind is that if your stock R is a little tired, you won't be able to pull 6th gear. I ride a Raptor now but I do miss my 3 wheeler, I had a lot of fun on it!
Old Jan 7, 2004 | 07:04 PM
  #17
QUADRUNNERMIKE's Avatar
what do you mean "pull" 6th? guess i don't know the lingo
Old Jan 8, 2004 | 12:19 PM
  #18
bigblock2stroke's Avatar
The motor may bog, or not accelerate all the way through 6th if your rings are a little worn and your not getting all the cylinder pressure that you used to get when the engine was new.
I had a similar issue on my R. It had smaller tires on it when I bought it (with a different rear sprocket). It was set up where it would pull through 6th pretty easily. One of the tires got a leaky valve stem so I put the stockers back on. Now you really have to hammer 5th gear all the way out and power shift into 6th to have the engine at a high enough rpm to produce enough hp to "pull' throgh 6th. But damn, if you do get it on the pipe in 6th you are freaking haullin'. I weigh about 190 and my buddy who weighs about 225 couldnt get 6th to pull at all, that's how close it is to needing a different rear sprocket with more teeth to numerically raise the final drive ratio.
Hope this helps
Old Jan 8, 2004 | 04:33 PM
  #19
definitely, thanks
Old Feb 23, 2004 | 09:59 PM
  #20
LittleBehaus's Avatar
Most people would say that a 250r is faster,
but if their both stock a 350x will beat it on top end
but 250r is faster on take off.
I heard that stock a 250r will run about 73mph.
A stock 86 350x which is faster than 85 runs about the same as a 250r.
86 350x
.040 wiseco piston
Cobra Exhaust
K&N FILTER
35 tooth rear sprocket
Getting white brothers cam and carburetor
