KF Honda ATC125 Frame & Engine ID Numbers
Old Feb 26, 2004 | 06:42 PM
KNOWSALOT's Avatar
The Facility
Default KF Honda ATC125 Frame & Engine ID Numbers
There are two completely different variations of the ATC125...The '84-'85 125M and the '86-'87125M.
Very few parts are shared between these two models.
The '84-'85 models used a horitzonal engine similar in design to the ATC110, but shares no internal engine parts with it.
The '86-'87 125 models use a vertical design engine that looks alot like a ATC200 engine, but again, shares no parts.
The '84-'85 models are 124cc, OHC, 4 Spd auto clutch trans with a dual range subtransmission. Electric and recoil start. No reverse gear.
The '86-'87 models are 124cc, OHC, 5 Spd auto clutch trans with Reverse. Electric and Recoil start. It also had front brakes.
All models are PassionRed in color.
Frame ID Numbers
1984.....JH3TE010*EC000001 and up
1985.....JH3TE010*FC100001 and up
1986.....JH3TE010*GK200001 and up
1987.....JH3TE010*HK300001 and up......This model received a keyed ignition switch
Engine ID Numbers
1984....TE01E-2000014 and up
1985....TE01E-2100001 and up
1986....TE01E-2200001 and up
1987....TE01E-8300001 and up
mr-tigger84
Jun 29, 2015 05:30 PM
gdmclnh
Jun 13, 2015 05:32 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
lovinhonda
Jan 25, 2000 09:17 PM
