KF Honda ATC200/S/E/ES/M Frame & Engine ID Numbers
OK.......This will be a good one...LOL
192cc
The '81-'83 ATC200 replaced the 1980 ATC185. It is the same basic ATC with changes to the piston,rings, and cylinder. It has a recoil start ONLY, 5 speed auto clutch transmission. Chain drive.
The '82-'83 ATC200E BigRed was a model designed for the hunter. Frame is very similar to the 200 differing in body mount locations. This model also had front suspension. The engine's top end is identical to the standard 200, but the bottom end shares few parts. This engine had electric start and a 5 speed auto clutch tranmission, but also had a Hi-Lo sub transmission. This model is chain driven.
The '84 ATC200ES BigRed was identical to the '82-'83 version with the exception of the rear frame section and drive train. This model was shaft driven. This model also had reverse. It was only made this single year, along with the design of the shaft drive.
The '84-'86 ATC200S replaced the ATC185S. Same engine as the old standard ATC200. The chassis received a few- small changes along with new body work and a redesigned seat that swept onto the fuel tank.
The '84-'85 ATC200M replaced the ATC200E when the ATC200ES arrived. The chassis is from the '82-'83 ATC200E, but the engine was a mix of the standard 200 and 200E. It was a 200 engine with the electric start from the 200E. No subtransmission was used on this model.
If alot of things haven't been changed to your ATC over the years, here's a quik way to lead you in the right diretion of what ATC200 model you might have.
ATC200......RecoilStart Only...........25" Tires....Chain Drive....No SubTransmission.......No Reverse.....1983 Had Front Suspension
ATC200E....Recoil & Electric Start...25" Tires....Chain Drive....Hi-Lo SubTransmission...No Reverse.....All Had Front Suspension
ATC200ES..Recoil & Electric Start...25" Tires....Sahft Drive.....Hi-Lo SubTransmission...With Reverse..All Had Front Suspension
ATC200S....RecoilStart Only...........22" Tires....Chain Drive....No SubTransmission.......No Reverse.....All Had Front Suspension
ATC200M...Recoil & Electric Start...25" Tires....Chain Drive....No SubTransmission.......No Reverse.....All Had Front Suspension
ATC 200 Frame ID Numbers
1981...JH3TB050*BC00004 and up...PassionRed...Black Pleated Seat...Headlight Control on top of Headlight...Small Chrome Gas Cap
1982...JH3TB050*CC10001 and up...PassionRed...Black NonPleated Seat...Headlight & Killswitch on left Handlebar
1983...JH3TB050*DC20023 and up...PassionRed...Hydraulic Front Suspension...DogLeg style Levers...Large Black Gas Cap
ATC 200 Engine ID Numbers
1981...TB05E-2000001 and up...All engines are 192cc...Recoil Start Only...5 Speed AutoClutch...No Reverse
1982...TB05E-2100704 and up
1983...TB05E-2200009 and up
ATC 200E BigRed Frame Numbers
1982...JH3TB051*CC133783 and up....PassionRed...Honda Decal on Tank is Red with a Black & Silver Stripe running below it.
1983...JH3TB051*DC203548 and up....PassionRed...Honda Decal on Tank is White with a Blue & White Sripe running up & down.
ATC 200E BigRed Engine Numbers
1982...TB05E-5000022 and up...All engines are 192cc/Recoil & ElectricStart.5 Speed AutoClutch..Hi-Lo Range SubTransmission..No Reverse
1983...TB05E-5100007 and up
ATC 200ES BigRed Frame Numbers
1984...JH3TB055*EC300001 and up....PassionRed...ShaftDrive...Front Suspension
ATC 200ES BigRed Engine Numbers
1984..TB05E-6000001 and up.All engines are 192cc/Recoil & ElectricStart.5 Speed AutoClutch..Hi-Lo Range SubTransmission with Reverse
ATC 200S Frame Numbers
1984...JH3TB053*EK300001 and up...PassionRed...Black Seat...Tank Stripe runs down the entire Fuel Tank
1985...JH3TB053*FK400004 and up...PassionRed...Tank Stripe only under Honda Decal
1986...JH3TB053*GK500006 and up...PassionRed...Blue Seat
ATC 200S Engine Numbers
1984....TB05E-2300001 and up...All Engines are 192cc...Recoil Start Only....5 Speed Auto Transmissions...Chain Drive...No Reverse
1985....TB05E-2500004 and up
1986....TB05E-2537514 and up
ATC 200M Frame Numbers
1984...JH3TB054*EC300005 and up...PassionRed...Fuel Tank Stripe runs down entire Fuel Tank
1985...JH3TB054*FK400001 and up...PassionRed...Fuel Tank Stripe only under the Honda Decal
ATC 200M Engine Numbers
1984...TB05E-5300004 and up...All Engines are 192cc...Recoil & Electric Start.....5 Speed Auto Transmissions...Chain Drive..No Reverse
1985...TB05E-5400001 and up
192cc
Note:
The 84 big red 200 es did not have rear suspension. The shaft drive housing and differential was mounted directly to the frame with no swingarm. The 85 250 es was the first big red with a rear suspension.
Thanks for pointing out my error. I know that the 1984 ES didn't have rear suspension.
I don't know if I was mixing info with the '84 TRX200 or the '85 250ES. Maybe neither. Took me along time to get it all done, and I called myself going back over it after I posted.......I missed it......LOL
I went back and edited....and went back over the whole thing again. It should be correct now.
THANKS
THANKS
