ATC roll call !!!!!!
Old Jul 25, 2004 | 02:35 PM
  #41
natedagrate's Avatar
Default ATC roll call !!!!!!
yep
Old Jul 26, 2004 | 01:16 PM
  #42
BigRed1985's Avatar
85 250es Big Red, it needs a throttle cable, 3 tires a rim a rebuild kit, handle bars new front end completley,but it still runs
Old Jul 26, 2004 | 02:25 PM
  #43
XC800's Avatar
Roger that, proud owner of a brand new 1985 mint 250ES Big Red!!
Old Jul 26, 2004 | 04:12 PM
  #44
nwcutie's Avatar
As far as ATCs, just have the little 70 - it's a great toy for all ages[img]i/expressions/face-icon-small-happy.gif[/img]
There were a ton of 3 wheelers down at Sandlake the last two weekends - some real beauties!
Old Jul 26, 2004 | 04:43 PM
  #45
Zerkie's Avatar
I have an 84 r that I just stipped down to the frame and repainted. I also just bought an engine that is polished, ported, bored 0.80 over, and with a hotrod kit engine. And to cmpiment the engine i got new exhaust, K&N, 38mm carb, and a G-3 reed cage with 12mm spacer from 1dirracing.
I also have an 84 200s. It is all in boxes sandblasted and primed.
Old Jul 27, 2004 | 12:17 AM
  #46
MyHatetredBleeds's Avatar
84 atc 200m. blown up twice, with $1200.00 put in motor work, and parts.
Old Jul 27, 2004 | 12:29 AM
  #47
PlatinumDogg's Avatar
What do you mean you've blow it up twice...what broke and how did it happen??
Old Jul 27, 2004 | 12:55 AM
  #48
it ran when i got it but it need a little work done. so i have paradise cycle do it, 2 days after i got it back, it blown up. so i took it to dave dickson, and he fixed it, and found a 1/2 inch long threaded pipe inside my case. and it killed my oil pump. and cause it to die. so i got it back ran great. timing chain snaped when in 5th gear pined going down a hill with no breaks. got that fixed, then it blown up again, got it fixed once again, did it my self that time. timed it wrong and bend an exhaust valve. fixed that and now all i need to do is set valve clearence, and it will be good to go. for about 2 weeks then something else will break.
Old Jul 27, 2004 | 03:18 AM
  #49
ThrashAndCrash's Avatar
DUDE......that is the most abused engine story I have heard of!!!!!! That poor thing!
Old Jul 27, 2004 | 07:45 PM
  #50
dragracer789's Avatar
Here[img]i/expressions/face-icon-small-smile.gif[/img]
200X
200X
250sx
tri-moto 200
