Whats the Stock Gearing on an 85 350X
I was just curious what the stock gearing is on a 350X? I just purchased one and it is geared 14/40, i wondered if the previous owner had changed the front sprocket to a 14 from a 13. It has 25x13.5 inch tires on the rear which will be coming off in favor of some 22x11 Holeshot XTC's.
Hunter.
Hunter.
the Stock Gearing is 13-40. i changed that on my 350x i put a 15 tooth sprocket on the front so it goes way much faster big difference between 13-40. if you want speed go for 15-40 biggest sprocket you can get for 350x. if you want top end go for 13-40.
I guess i will wait untill my tires come in and i get them mounted to decide on gear selections, since that is probably throwing it off somewhat.
My86-
Did you mean to say for low end and torque go back to a 13 tooth, you said top end for 15 tooth and 13 tooth.
My86-
i Meant Low End. and on 15 get lots of top and tons of speed. but on 13 youll go slower.
on my bike have Turf Tamers and there great tires and look great. im thinking of getting a bigger rear sprocket if i can find one
