what do i need to do
A good carb dip will be needed after the fuel varnished then evaporated, also check the tank since it has surely started to rust by now.
Spin her over with the plug out and hooked to the plug wire and see if you have spark to make sure there are no electrical problems.
Otherwise just give it a good cleaning and look over.
Good Luck
Jeff
Good Luck
Jeff
