350X Axle Bearing trouble
Old Feb 27, 2005 | 02:34 AM
MY86ATC350X's Avatar
Default 350Axle Bearing Issue
im trying to replace the axle bearings but i cant remove the hubs and the big bolts on the right side next to the disk brake, i think there's a clip in between the chain hub and the big bolt hub how can i remove those out.. please help im totally lost here, i need this bike ready for pismo next friday. anyone?
Old Feb 27, 2005 | 09:10 PM
chipdog4's Avatar
Default 350X Axle Bearing trouble
You really only need to take the hubs off the one side that has the big nuts on it. I think its the brake side. Take the wheel hub off, then the big nuts, and then the disc hub should slide out and you can then push the axle out.
Old Feb 27, 2005 | 09:18 PM
yea but i think next to the big bolt there is a clip. i tried removing the big bolt and i cant, i see a a clip there but i dont know how to remove it. or is that clip just there?
Old Feb 27, 2005 | 10:00 PM
chipdog4's Avatar
A cotter pin? You just have to put a pair of needle nose pliers on it, straighten out the bent ends and pull on the looped end. Or you can just cut it off with a pair of sidecuts since you will have to put a new one on when your done.
Old Feb 28, 2005 | 03:39 AM
SNTx2's Avatar
If your talking about the preload nut and jam, you have to screw it inward (left hand thread by the way) toward the center enough to get the metal ring pushed inward and then remove the clip inside that ring. Then remove everything to get to the carrier bearings. Really easy when you finally figure it out, been there, wrestled with it for a few hours myself.
Old Mar 1, 2005 | 03:32 AM
Thanks alot man it worked now i have to think to remove those old rust bearings out. but thatnks everyone for your help.
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
1000gade
Sep 9, 2015 04:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
