im a newbie, in need of help on 82-81 atc 200
Old May 8, 2005 | 11:08 AM
getrdone's Avatar
Default in need of help on 82-81 atc 200
this might sound stupid but i have an 81-82 atc200 that i just bought and i know nothing about it, it did not run when i got it but i now have it runnin sweet my problem is it did'nt come with any of the shifters, on the side that the pull starter is on there seems to be two spots for two shifters or maybe ones the shifter and ones the kick starter i don.t know, so if anyone has any pics of this setup or knows which is which i would be greatly abliged. thanks, john
Old May 8, 2005 | 08:27 PM
haywoodjalikme's Avatar
Default im a newbie, in need of help on 82-81 atc 200
One 'post' is for the shifter and the other points to what gear your in( I'm assuming the pointer is missing )
The 'post' farthest back and sticking out the farthest from the engine I would assume is the shifter, it should also be bigger in diameter.
I haven't seen a regular 200 for a while but think the info is correct.
Shifters are available from www.denniskirk.com for $18.95 part number 59-627
Hope this helps
Jeff
Old May 8, 2005 | 08:30 PM
Oh yeah there should be a N for neutral on the case or recoil cover really close to the post which is the indicator, then the other post would be the shifter.
Jeff
Old May 8, 2005 | 09:42 PM
getrdone's Avatar
that was a great help the big one is the shifter it was jammed and would not move but after your help i got it broke loose works great, is there any way to know forsure if the clutch is shot or not, thanks alot john
Old May 9, 2005 | 07:19 PM
Hey John
Its been since the early 80s when I had a wheeler with a centrifical clutch so I'm afraid I can't help ya there.
Your best bet is to post a NEW topic with a subject with centrifical clutch in the title, there are lots of smart people that view this forum, 'KNOWSALOT' and 'THRASH AND CRASH TIL ITS TRASH' will probably will probably give you some good advice sooner or later.
Jeff
Old May 9, 2005 | 07:29 PM
getrdone's Avatar
thanks for all your help jeff
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
that1redhead
Sep 8, 2015 11:47 AM
