200s flywheel question
Old May 13, 2006 | 10:22 PM
Fencer's Avatar
Default 200s flywheel question
I have the honda manual and it stated the torque, but it is vague at best when it explains things. Will you feel any sort of a POP or feel that it has secured its self into the position when putting it back on. Does it feel like you are tightening any other bolt? (ie. no POP indicating that the flywheel is on and in the correct spot) All I need is your experienced perspective on this.
Old May 14, 2006 | 12:23 AM
jonnyneutron's Avatar
if it is a keyed fly wheel the fly wheel nut just keeps it from flying off it should sit on the shaft in postion corrctly with no nut on it , i usually but a small drop of lock tite on the threads and tighten it up but not torque it down a whole lot just nice and tight hope it helps jonnyneutron
Old May 14, 2006 | 12:37 AM
Fencer's Avatar
Thank you very much. I was just hung up because a person needs a puller to get it off but nothing special to get it back on. Seems odd. Now I should be up and running.
Old May 21, 2006 | 03:38 PM
Campbelltx's Avatar
how did you get the flywheel off. I broke my puller trying to remove it.
Thanks Andrew
Old May 21, 2006 | 04:23 PM
medeff's Avatar
you can buy a puller for 10-15 dollar or buy a M14 X 1.5 X 50 bolt the bolt works just as good for a dollar or two. then just pop it a few times with a impact gun
Old May 21, 2006 | 04:38 PM
Fencer's Avatar
I ordered a puller thru a shop but they messed up and got me the puller for the 200es. I ended up just having them pop it off. It takes one thing to be threaded on the inside of the flywheel and then a bolt gets threaded down to push the puller off. Not sure what other methods may work.
Old May 21, 2006 | 04:48 PM
Campbelltx's Avatar
hey medeff
On your method all i have to do is impact that 14mm bolt on and i will pop off or is there something else needed
Old May 22, 2006 | 11:17 AM
lawnboymelvin's Avatar
i used the M14 X 1.5 X 50 bolt on the 200m and i used the impact gun and it came right off didnt reck threads at all wow[img]i/expressions/face-icon-small-shocked.gif[/img] but the 200s i made a flywheel puller out of a mower blade check photo page [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 18, 2006 | 07:51 AM
crazyrider1's Avatar
no it slides on
use lock tight on threds when installing
a puller is like 10.00
the crank is tapered so it slides up on the crank over a woodruff key until it is seated fully
Old Apr 18, 2007 | 03:48 PM
loadder's Avatar
i have the 14 mm part from honda, where do i use it at , in the 2 holds on either side of the shaft , i dont see where or how it would work any other way, what does it screw into ??
chingchangchong
Aug 7, 2022 11:36 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
theddaug
Aug 15, 2015 09:17 AM
kdg723
Jul 25, 2015 01:20 PM
