1984 200m
Old Aug 14, 2006 | 05:12 PM
Tomeboy56's Avatar
Default 1984 200m
I have a 1984 Honda 200 m three wheeler and I want to change the sprockets. The problem I'm having is taking off the rear sprocket. I have all the nuts off that I thought was holding the sprocket on but the sprocket will not come off. Am I missing something? Could someone maybe have the answer? Thanks
Old Aug 14, 2006 | 06:05 PM
HondaAtcRoxz's Avatar
Default 1984 200m
It is probably held on with rust. Spray it down with some good lubricant and then tap it both ways to loosen it up. Then when you get it moving some and if your takin it off and it sicks again hit it back the other way and continue until you remove. This will remove the hub and sproket. Other then that I dont know what else would be holding it on.
timster911
Jul 13, 2015 01:57 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
jeannor
Dec 8, 2004 03:13 PM
thrashed200m
ATC 3-Wheelers
Apr 23, 2003 08:36 PM
sweetpea
Apr 20, 2003 07:23 PM
