310 short rod vs long rod
Old Oct 3, 2007 | 02:34 PM
310blur's Avatar
Default 310 short rod vs long rod
I have an ESR 310 short rod in my trike and want to go to a long rod but it requires me getting a spacer plate and my spark plug boot allready hits the frame everytime i change a plug I have to take my gas tank off anyone else have this problem what did you do to fix it any suggestions thank you
Old Oct 25, 2007 | 12:47 PM
carl250r's Avatar
i bet you have a aftermarket head that the plug screws into strait up in the middle.
if you get a stock head and have it redomed for teh 310 i bet you will be allrite
and teh stock heads have a motor mont on them that bolts to teh top frame tube . wich would be good to have running a 310 long rod. i have cracked the frames on these bikes 2 different times at the bottom motor mount when not running the top mount and having a strong hopped up motor.
Old Oct 27, 2007 | 02:01 AM
3ismorethan4's Avatar
If he ran a long rod with the stock head the head/frame mount wouldn't line up because of the extra hight of the cylinder with the spacer plate under it.
Old Oct 27, 2007 | 10:18 AM
carl250r's Avatar
good point.
i recomend trying to make a mount then, a little strap of steel with a few bolts through it ,should not be to hard to make.
i think the stock head would be easyer to get the spark plug in and out of though
fd24
Jan 16, 2019 08:59 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
