Help
Old Jan 20, 2008 | 01:53 AM
Silkdws22's Avatar
Default Help
Hi, My name is Dale and this is my first time posting something on here. But heres my problem. I just bought a honda 250 Sx about a week ago the guy i got it from said the u joints were bad and that was it but when i got the swingarm off i seen the rear yoke of the drive shaft was busted so i got to get a drive shaft for it and also the part where the drive shaft goes into the trans was cracked, i thought that it was just a cover so i took out the 3 bolts holding that into the trans and the whole shaft came out and the gears fell off into the trans, so i tried to get it back into the trans by pusing it and turning the little gear and i finially got it to go back in so i tighted down the bolts and now the output shaft is really hard to turn i mean i put the yoke on and i had to use a pipe wrench and before i could just turn it with my fingers no problem i would really like some help with this it is my first 3 wheeler and i have no idea what i did
