honda 70 84
Old May 24, 2009 | 01:53 PM
honda7083's Avatar
Default honda 70 84
i just put a new carburetor on my 70 and we pulled it behind a car and it started but had no power and would die when we stopped can someone help
Old May 24, 2009 | 10:50 PM
honda7083's Avatar
i have used a drill and shifted into frist gear and it started 2 move but just would not run
Old May 25, 2009 | 05:07 AM
HondaMechanic's Avatar
Why did you change the carb in the first place ..?
Old May 25, 2009 | 10:13 AM
honda7083's Avatar
i wanted a backup so i am going to rebuild the old one but i thought the new one would b better . i got it off ebay 4 $50 at wincycle
Old May 25, 2009 | 04:40 PM
honda7083's Avatar
it needed cleaned bad no gas washardly getting 2 the carburetor the peecock was bad
Old May 26, 2009 | 11:27 AM
honda7083's Avatar
not getting gas why
Old May 27, 2009 | 08:55 PM
MadMel777's Avatar
did it run with the old carb ... is the ports (or screen) in the tank plugged ? .. gas cap venting properly?
Old May 27, 2009 | 09:30 PM
honda7083's Avatar
no the oldone needed cleaned bad and not clogged.had gas cap off .it is getting to the bowl can u adjust the float and how? thank u
Old May 28, 2009 | 07:03 PM
MadMel777's Avatar
yes it can be adjusted ... try this sight to look at the manual
http://72.52.143.80/~trikes/atc70-12...vicemanual.pdf
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
