honda 200x confusion
Old Nov 4, 2010 | 05:04 PM
Digity17's Avatar
And thanks for the help yall. I would be SOL without ya.
Old Nov 4, 2010 | 05:48 PM
sdm111's Avatar
2 strokes or 4
Is the throttle cable kinked or fitting tight under the gas tank? Or getting caught up? Sounds like it's binding.
Old Nov 5, 2010 | 04:00 PM
Digity17's Avatar
Il check the cable tonight....but i cleaned the carb and put the rebuild kit in and it idles now..jut my other 1 that has a preformance exhaust on it won't idle...and i cleaned it and blew it out with compressed air and put the rebuild kit in...
Old Nov 6, 2010 | 09:00 PM
DirtMX57's Avatar
Exclamation Bike Problems
I'm having problems with my gear shifter. I bought a bike months ago from this guy on craigslist. it had a honda ATC engine ( i beleive it's a 81) and a Yamaha quad body on it, it ran fine, until i tried changing the oil.....well i couldn't get the drain bolt to crack so i pumped the oil out then added new oil. okay then.... it wouldn't change gears! my gearshift wont hardly move! like i have to push HARD and i even bent it in the process. so then i found a screw just above the hi/low gearbox and it looked like i could add gear oil in it..ok i put gear oil in and fire it up...still wont go! so then one day i played around with the screw above the gearbox and found out it had a springand the thing that switches it from hi to low well the spring fell down inside the dang gearbox!!! i'm at a dead end here guys!!! someone please help!! I want to fix it so badly! I put alot of money into this bike by buying parts for the recoil starter,buying a hose for carb and spray painting it. so i really want to fix it. I cant mess with it til 2011 because i'm having a knee re-alignment coming up soon. but if you would, please study it for me? i'm a do it myself girl and i've learned alot of stuff on my own just by messing with bikes but i'm stumped here.
Thanks,
Jessie
Old Nov 7, 2010 | 09:44 AM
  #15
Digity17's Avatar
please..start your own post so everyone can see it
Old Mar 1, 2011 | 12:14 PM
  #16
drew69's Avatar
Default Hey
It's your throttle cable replace it or adjust it mine did same thing
Old Mar 13, 2011 | 12:59 PM
  #17
venn1979's Avatar
Check your throtle. It sounds like that might be your problem. Good luck!
bigred20653
Aug 31, 2015 12:41 PM
Aug 18, 2015 01:00 AM
house1
Aug 9, 2015 10:49 PM
Schneider
Jul 24, 2015 05:05 PM
