81 honda 250r atc
Old Jul 21, 2014 | 05:11 PM
Alexx Abrunzo's Avatar
Default 81 honda 250r atc
i rebuilt the top end about 2 weeks ago been running fine, breaking it in then i decided to take it on a short ride, well all well and good till i get back to the street it just loses power and shuts off , wont start back up, never went past half throttle, iv change the oil 3 times so far and one of the times was before i went for the quick ride,
Old Jul 21, 2014 | 06:06 PM
If you're talking about changing the transmission oil,that shouldn't have anything to do with the top end. Did you have the cylinder bored to the next oversize that would clean it up,plus did you check or replace the rod,lower rod bearing and crank bearings or just do the top end only? Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet
Old Jul 21, 2014 | 08:22 PM
yes i had the cylinder bored out to .20 overs rod bearings were replaced .all bottom end bearings were replaced , i put a new bigger 34mm carb on , my plug is a blackish color
bike has everything stock other then the cylinder bore at the moment
stcspiderman
Sep 13, 2015 05:15 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
