Camshaft help
Old May 29, 2002 | 02:36 AM
crq350x's Avatar
I am going to be doing some work to my 86 350x motor And I cant figure out how to remove the cam shaft any help would be great.
Colin
Old May 29, 2002 | 10:00 PM
crq350x's Avatar
Hello
Old May 29, 2002 | 11:12 PM
KNOWSALOT's Avatar
The Facility
On the 350X engine, the valve cover must be removed to take out the cam. The ones that I have been into have been on 250X frames, so I had to remove the engine to do this. I'm not sure if you have enough clearance on the three wheeler frame to do this without removing the engine or not.
If you haven't done this before, I strongly recommend that you buy a repair manual, because there is no way to post detrailed instructions on this forum that would be easy to understand.....not to mention the steps involved in putting it back in and timing it.
Good luck.
Old May 29, 2002 | 11:59 PM
crq350x's Avatar
thanks man Well the three wheeler is a halfbreed it has ben made into a 4 wheeler and the motor comes right out.
Colin
Cole Hadden
Jun 15, 2025 09:05 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Polarisman1123
Aug 3, 2015 02:08 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
