250R Parts (Hey B. Pace, I need some help!)
Brad, I recently purchased a mx ready '87 250r. The problem is after riding for about a week I threw the chain and cracked my center case. I need to know where I can get a good used or new case. Also I am putting the clutch back to a stock setup vs. the racing setup and I am told that I need a new "inner" clutch basket, but I have never heard of this part, could there be another name for it.
Any help would be appreciated.
Thanks, Chris
Thanks, Chris
I'll check aroung for a used case for you. You can always get you a new one from Honda for around $200. Invest in a case saver. The clutch part you are needing is called the "clutch center" or "clutch center hub". If you look at the clutch pack with the pressure plate removed, it is the piece in the middle being held on with the big nut. You will have to get this part from Honda.
i think nac's has them there number is 914-246-3086 and the web site it does not list it www.nacsracing.com/
MikeyBoyesq
Aug 10, 2015 11:11 AM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
