Octane Boost?
Old Jan 19, 2002 | 11:43 AM
MxTrx250r's Avatar
I just bought some 104 octane boost for my truck it comes in a litle black botle. It says it will treat 83 litres and increase octane about 5 points. I know this is most likely a stupid question but, What if I used this in my quad but only use it on say a 25 gallon can or two (22 litres each) would this hurt anything on my twostroke engine in my 250r?
because i have heard that many additives are not good for high performance two stroke engines.
Old Jan 19, 2002 | 06:11 PM
250rampage's Avatar
Unless you are running a high compression engine, octane boost won't do a thing for performance.
Old Jan 19, 2002 | 08:32 PM
MxTrx250r's Avatar
I am running a higher compression engine and plan on running even higher. Will the octane boost do the same as race gas without hurting my engine?
Old Jan 20, 2002 | 04:48 PM
Blastermaster's Avatar
it should not hurt any thing but if i were you i would run race gas that way you know what the octane level is
Old Jan 20, 2002 | 06:31 PM
seven's Avatar
I have run the octane booster in my banshee and my 250r when i cant make it down to buy av gas.It will not hurt your motor in any way.There is another topic about running av gas instead of race gas also.Av gas is only 2.40 a gallon instead of 5.00 a gallon for race gas.Its actually cheaper to do iy that way instead of octane booster
Mikegriff92
Technical and How-To Articles
Oct 26, 2015 02:40 PM
Polaris-400
Aug 19, 2015 02:20 AM
Aug 18, 2015 01:00 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
