ATV RACING ????????????
Old Sep 22, 2002 | 01:00 AM
crankase's Avatar
Is it true that the front of your quad is supposed to be wider than the rear?If so, why?
Old Sep 22, 2002 | 02:07 AM
YFZRacer's Avatar
if the back is a lot wider then the front it doesn't turn near as well
Old Sep 22, 2002 | 10:45 AM
Kurt400ex's Avatar
it is a better idea if you get the rear axle wider that you have to do the same to the front, then it will be 50x easyier to turn and race faster.
400ex
Jet kit
K & N
Holes in Air Box
Nerf Bars
Bumpber
front and rear wider axles
Old Sep 25, 2002 | 07:22 PM
RacinJason's Avatar
when going through rutted corners the rear will want to "push" the front end instead of following it...I had an axle for nearly 8months w/o a-arms and every moto was an arm pumping experience...a-arms solved the problem
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
