Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
Should I buy a kfx700?
Old Dec 6, 2003 | 03:27 AM
RPM's Avatar
RPM
Default Should I buy a kfx700?
The KFX700 is its own animal. Some will Love it, and some will Hate it. I happen to Love it. I make a habit out of taking people up on the opportunity to ride every different ATV I can get my hands on. I have ridden everything from a Breeze to a YFZ450. I will say this for the 700, it may not be the best at everything, but it does everything pretty well. Enough so, that I personally feel that it is the most versitile all aound Sport Quad on the market today.
On the plus side:
Great Torque
Low center of gravity
Good ground clearance
Climbs hills with ease
Easy to ride
Makes you feel like you can go anywhere
On the minus side:
Getting use to going down hill
Not the best on gas milage
Heavier than other Sport Quads
Makes you think you can go anywhere
Good luck with whatever you choose.
Old Dec 6, 2003 | 08:38 PM
chrisz250's Avatar
go wit a yfz450!
Old Dec 8, 2003 | 01:56 AM
iwannaatv's Avatar
I'm starting to forget about the kfx for the yzf450. The kfx seems to be too heavy, 516lbs vs 350lbs.
Old Dec 8, 2003 | 01:40 PM
RPM's Avatar
RPM
I have ridden both, and this is what I can tell you. Depending on the type of ridding and the kind of terrain you will be riding on, they are apples and oranges.
I ride heavily rutted, muddy trails, and under those conditions, the YFZ is no match for the Big 700. Here is why. Ground Clearance! The Shaft drive on the 700 gives it more ground clearance and the 700 still has a very low center of gravity. The main thing you will notice is the combination of the Auto Trany and the second to none Torque of the 700, which makes most obstacles of little concern.
The YFZ has a disadvantage with its chain drive (Less Ground Clearance) and I felt that I had to keep the RPM's up to negotiate the technical sections of the trail. If the Dunes are your thing, then it is NO contest, YFZ all the way. In fact I am currently considering selling my KFX400 and getting a YFZ.
Old Dec 8, 2003 | 10:18 PM
  #15
fmxc's Avatar
IMO auto tranny isnt all its cracked up to be,.. i feel like i have more control with manual clutch and tranny and a kfx700 isnt exactly the easiest to throw sideways in a turn, but still fun. If you just want a bike to hop on and have some fun and you wont be gettin into really "extreme" riding the 700 is great for you, and looking at your age it sounds like you would have the most fun with a kfx400 or 400ex
Old Dec 9, 2003 | 12:59 AM
  #16
Mr45auto's Avatar
The V force would be an excellent machine for a beginning rider. It's powerful enough you wont be bored with it easily, it has good ground clearance for trail rides, should be easy to learn on and enjoy even with more experience. It should be a great do all quad. I personally dont want one but I've been riding for several years and it's just not my cup of tea. I have ridden one however and I did enjoy it. It seems pretty potent, has it's drawbacks but so does everything else. I think for a beginning rider it would be a better choice than the YFZ450.
Old Dec 9, 2003 | 07:46 PM
  #17
iwannaatv's Avatar
Ok, i'm sticking with the kfx since rpm convinced me. The ground clearance advantage really affects my decision also the reverse gear.
Now some questions on mods, this thing is full of power so later on when i'm more skilled i'll add on a-arms that are stronger and 1" wider with a 1" wider axle. Do you guys think these mods would be necessary. I'm also thinking of dual stainless steel mufflers which would look sweet with a lava red kfx.
Old Dec 10, 2003 | 02:41 AM
  #18
RPM's Avatar
RPM
In all honesty, the KFX700 is more than wide enough already. The one thing that you might consider is stronger Tie Rods.
As far as performance upgrades are concerned, the Dual Exhaust is a good way to boost performance along with the other necessary changes (Filter & Jets), but be careful not to exceed the noise limitations of the state you live in. It's becoming more and more of an issue every day. It's the new catch-all complaint by the ATV Haters Association.
The potential of the 700 is yet to be fully understood, but one thing is for sure if you want to get the most out of it, you will need to learn as much as you can about the Auto Trany. This is the area that you will see the biggest gains for the least amount of money.
Good luck, and be Safe.
MikeyBoyesq
Sep 7, 2015 10:44 PM
AlbyKawa
Oct 7, 2003 11:13 AM
AlbyKawa
Sep 9, 2003 12:28 AM
MALOCHALA
Sep 22, 2002 02:41 AM
