Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
What do I do please help!
Old Feb 17, 2013 | 04:54 PM
GhostMP's Avatar
Default What do I do please help!
So I purchased a 2011 kingquad 750axi from a dealership, the dealership sold it to me as new even though is had some scratches and some other minor stuff. Once i purchased the atv I brought it home to only find out that it have 50 hrs on the bike and about 40miles, now since the shop sold this bike to me as new and so does the paperwork say what can I do. The only reason I am asking is because i have had the atv for about 3 or 4 weeks now and it has a hard time starting and it has been in the shop for multiple issues is there any thing legal I can do, also one of the employes told me the atv was prolly used as a loaner.
Old Feb 17, 2013 | 08:22 PM
mudslinginfool's Avatar
Does it in the Mud!
It was probably a demo bike which means every one test drove it before you bought it. if its sold as new then it has a warranty. take it back. it should at minimum have a 6 month warranty. Also, have you checked the battery? if its EFI it requires a good charged battery to get it started as the fuel pump needs to build correct pressure. put a volt meter on it turned off,then check it while someone hits the start button and see what the voltage drops down to. Im unsure but if it drops below 11.5 volts it may not be enough. Youll have to verify that though. what the minimum voltage reading is under load(starting)
