which is better Recon or beartracker, Help?
I would push more toward the Recon due to the history of the Beartracker. Yamaha came out with it as a replacement to their Timberwolf that had a strong reputation for being underpowered. They basically increased the intake of the carburator and gave it a slightly longer stroke to deliver more power.
The Recon has been touted to have plenty of power but yet somewhat cold natured. Some owners have even reported it does not idle well until warm. It also does not have a conventional type oil filter that can be easily replaced.
I'm also looking for a quad and looked at both of these. I personally liked the beartracker better myself. I rode both and the bear tracker seemed to be just fine on power...especially for a 250. Plus it's got a full size chassis. The recon seemed a little small. To me it looked like a toy.
I just rode a friend of mines BearTracker for about 25 miles or so. It is his wifes and need to run it and had me ride it so I left my Wolv. at home. The BearTracker was fun. I'm 6' and 215lbs and rode mostly trails with it. It was pretty fun to ride and it was really fun for me to do wheelies on and to jump some over small bumps and stuff like that. I was surprised how the little machine ran for a 250 sized machine. It was a nice change and would make a great 1st machine. The suspension is resonably plush again for its size. I was not beat up at all and we rode some rough stuff with lots of rocks. All in all it was a fun change for me to ride the BearTracker.
Greetings,
Dirt Wheels did a good comparison on the full range of 250s out there. The Recon won hands-down. I'm 6'2" and 240lbs and it hauls me around without a complaint. Now, if you're a big person, you'll find it a bit too small, but I get a kick out of it as an alternative to the bigger 450ES I have. In fact, I use the Recon on some work projects because I can ride it with only one hand on the bars, the ES requires the left for shifting. But in any case, the Recon is tough and well powered. The ride is lighter feeling than the big 4X4 but that's to be expected. They have a well-earned reputation for being cold-blooded but its not a big issue -- just let it warm up.
Just another opinion but I think the Recon is better made and better to ride. If you look under the front end you will see the Recon has a double tubed a A arm suspension compared to the Beartrackers single flat metal a arm. And the reverse is easier to engage on the Recon. Especially if you are in semi deep water. We've owned two for about 1 year with no complaints.
The reason the Beartracker has only single a-arms is that it uses MacPherson Struts. The Struts support the weight of the front end. It is just as strong as the recon's front end. I had a Beartracker, when when I owned one they were called Timberwolf's, almost the exact same quad, anyway it was reliable and fun to ride. It has plenty of power and now they added front disc brakes. I would highly recommend it, they are great quads.
