is tuning needed
I have a '09 Outlander 800R, I want to get a pipe for it. I have two in mind, Aaen or HMF slip-on! Is tuning needed, like a power commander or something? I've heard that the Aaen pipe doesn't need tuning; but the HMF does. I've heard sound clips of both. They sound great but the HMF just has morte of that I'm the King Of The Forest growl!!! Any tips which one is better. Help and advice would be great!:huh:
Welcome to the forums. :)
Most quads can take just a slip on exhaust without having to rejet. Best thing you can do after you put it on is do a plug chop and see where your machine is in that group. |
Thanks! I have another question what is a ( plug chop )? My Outty has EFI,no carb to jet. What does this plug chop do? Thanks for the info!!
Since you have efi, you wouldn't have to worry about it.
Basic plug chop is putting in a new plug, running the quad about 1/4 wide open and shut off the ignition. Pull the plug and see what color it is. From there you would determine if you were lean, rich or right where you need to be. Now the bad news is, if you do a whole lot to the intake/exhaust, you would have to remap your system. |
Originally Posted by Scootergptx
(Post 2845744)
Originally Posted by Stoopidbot
(Post 2845751)
Why wouldn't he have to worry about it since he has EFI? There is no o2 sensor to adjust for fluctuation in the intake or exhaust. The efi only compensates for elevation change. Thaa is the down side to efi, any upgrade to the pipe or intake you have to buy a fuel programmer. On my Rhino with EFI I had to add nearly 25% more fuel at certain spots of the RPM range to get the ratio correct.
So it really does depend on the specific machine, and what pipe you choose. And of course your elevation..... It will also depend a lot on if you do airbox or intake mods. |
I wasn't saying anything about that. I got a slip-on before the head pipe, I did not have to rejet for mine either.(until I put the header on)
I was questioning when the guy asked what is a plug chop, and his response was, You have EFI, you don't have to worry about it. That is what I was wondering. |
(Post 2845799)
AH, I see. I thought you meant because he has EFI he doesn't have to check...
You will know instantly if you need to rejet for the slip-on. |
no need to worry about adding fuel with the addition of a slip on.BRP already has these machines running rich to try and keep them cool. i have had a slip on on my ol650 for over 3 years now,4500 miles with no issues, and the plugs still show a little on the rich side. just remember, your not letting more air in, just getting it out faster. if you do an intake mod then you will need more fuel.
