HELP! GAS IN OIL???
Old May 25, 2003 | 11:58 PM
BillXR's Avatar
Default HELP! GAS IN OIL???
This is the second time! Someone said last time that I shouldn't leave my gas on while it sits. Said it would run out carb and get in the oil! Is there something I'm missing here?
Old May 26, 2003 | 02:14 AM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
are you sure it isnt anti freeze? i do not see how gas could get in oil, unless im missing something....anyone?
Old May 26, 2003 | 09:10 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Check to make sure that your choke is all the way in. When I first bought my DS, my choke would stick in the first position and the bike would run very rich getting noticeable gas in the oil.
If the float needle doesn't seat, gas should come out the overflow hose. Check to see if it is plugged in the end. If the needle sticks or doesn't seat well gas will run up into the carb throat and into the cylinder. Yes, if you park the bike for you should turn off the gas.
Old May 26, 2003 | 03:44 PM
TyreSpinner's Avatar
Umm, when I let my float overflow tube hanging with the gas on...there's fuel that drips out of it...So your saying it's not supposed to be like that?!?
I run a TM45.
Thanks
Edit : My bike is running quite rich...Could this be the cause??
Old May 26, 2003 | 05:15 PM
Hightower's Avatar
if gas drips from the overflow/vent tube, then that measn the needle valve on the float is not shutting gas off, which in turn also makes the bike run rich, and can allow gas into the oil when the bike is sitting, like mystereid said.
Old May 26, 2003 | 05:18 PM
Aaaah. That's not good. HOW CAN I FIX IT?!?
Help. Thanks
Old May 26, 2003 | 05:19 PM
Uh, so that means I have gas in my oil too....grrr
Meaning oil change ASAP?? or is it harmless?!?!
Old May 26, 2003 | 07:34 PM
BillXR's Avatar
Grrrrrrr...I just got this thing with less that 5 hrs on it! It's not that I don't mind wrenchin on stuff...IT's I'm not familiure at all with this beast. The little I have done to it is a pain in the ****' because they use nylocks on EVERYTHING!!!! You can't take a bolt of with out two wrenches!.
I'll try what I can...Thanks for ther replys
Old May 26, 2003 | 10:51 PM
mystereid's Avatar
Hey, bite your lip, it's those nylocks that keep your bike together. Go ride with Raptor guys and watch the parts fall off.
What is hard to work with is that they must use locktite on the carb bowl screws.
Old May 27, 2003 | 12:09 PM
Can someone help me fix my problem. ^ or see my new thread.
Please.
