What is in your garage, part two
Old Jul 23, 2003 | 02:31 AM
  #21
PUSHINTHELIMIT's Avatar
Default What is in your garage, part two
Is there any AFTERMARKET heel guards out there? How about used nerf bars? How about some black shock covers? Thanks guys.
Josh
Old Jul 23, 2003 | 03:00 PM
  #22
DemonDS's Avatar
I have a set of Sand Devils(the streight ones) on Douglas 190's for a rappy. Like brand new!!! Will sell for cheap. I am moving so I need these gone.
Old Jul 23, 2003 | 09:12 PM
  #23
Ds650RaCeR's Avatar
wanting to trade my yoshi slip on for a diff slip on for the ds
Old Jul 24, 2003 | 02:42 AM
  #24
Ds650RaCeR's Avatar
need yellow plastic also...
Old Jul 27, 2003 | 10:08 PM
  #25
DaSandBomb's Avatar
got a 2000 blaster with fmf pipe pro curcit silencer. etc pm me
Old Jul 28, 2003 | 12:06 AM
  #26
blastnbaja's Avatar
anyone have a rwr cdi for sale. pm me
Old Jul 28, 2003 | 04:28 PM
  #27
DCryder's Avatar
Brand new RWR cdi
22x8-10 Front Max tires with 99.9% tread left
Baja handguards
aluminum custom endcap for stocker w/ 2.75" outlet
Old Jul 28, 2003 | 05:42 PM
  #28
fastone21's Avatar
I have a 2002 Ds 650 baja will trade for street sport bike 99 or newer and 900cc or better
baja plastic
Hmf exhaust
Ron wood cdi
Prm grab bar
400 ex
oneal riding suit black and greg Used twice size 38
blk flamed helmet
Old Jul 28, 2003 | 05:47 PM
  #29
ScoobyDFW's Avatar
likely moving soon...
1) DS durablue axle
2) DS durablue sprocket hub
3) sand tires unlimited 22x14x10 mini-desert-traks on douglas .190 DS rims
4) 23x7x10 ITP holeshot XCT on damaged .190 DS rims
5) 22x11x10 titan trail claw II not mounted
6) bent & twisted +8" aluminum TVI swingarm
7) stock rear sprocket
8) stock CDI box
9) stock muffler
10) stock swingarm
11) stock rear shock
12) stock front shocks
13) stock upper a-arms (2001)
14) weak stock battery
15) parts from first turbo setup - turbo, airbox, BOV, intercooler and pipes, head pipe, etc.
16) HSR42 carb w/factory polish
17) ron wood ported intake for 45mm carb
18) MSD boost timing master ignition
19) stock flywheel, starter gears
20) clutch cover with a crack
21) outer clutch hub with a missing tooth on gear
22) oil pumps
23) cylinder w/oring (one bad thread)
24) new stock piston
25) stock clutch springs
26) stock valve springs and retainers
27) coils without caps
28) rear grab bar
29) a few EFI related parts
30) clutch pressure plate
31) new stock head gasket
32) 0.043" copper head gaskets
33) used stock valves
34) stock heat shield
35) NGK plugs - various heat ranges
36) gaskets
37) oil filters (2001)
38) transmission dogs
39) crank & countershaft shims (different sizes)
40) oil pressure switches
41) thermostat
42) fan switch
43) overtemp switch
44) portable 5 gallon pressure washer (12VDC)
45) receiver hitch and ball
46) stock heel guards
47) answer boots
48) 20 gallon air compressor, impact wrench
49) bunch of 5 gallon jugs (all full of methanol right now)
50) 2.5 gallon pure nitro
51) stock flywheel hub
52) radiator cap
53) broken stock crank (rod and bearing good)
54) slightly bent PRM desert grab bar
55) woods tach damaged from accident (might still work - for tuning)
56) more stuff, can't remember it all...
Old Jul 28, 2003 | 08:45 PM
  #30
QUADMAN650's Avatar
DS650 OVER 2000 INVESTED
I WILL SOON HAVE SOME SETS OF DRAG PIPES
96 SEADOO XP
2002 YAMAHA 125L 4 STROKE
I NEED A SET OF STOCK REAR WHEELS AND ALMOST BALD DOMINATOR TIRES
