Ceramic Coated Headpipes?
Old Oct 15, 2003 | 11:05 AM
Oldmanracing's Avatar
Default Ceramic Coated Headpipes?
Has anyone had their headpipes coated and was there any horsepower increase noticed?
Old Oct 15, 2003 | 11:12 AM
ironrod's Avatar
Ceramic coated headpipes have been done on a commercial basis for several years. This includes Ron Wood Racing with external coating and Big Gun who coats all thier pipes externally and internally. They both say it helps with heat dissipation and therefore increases horsepower.
Personally, I've seen the Ron Wood Pipe's coating burn off. I am not a believer in ceramic coating as far a wear is concerned.
Marky
Old Oct 15, 2003 | 11:22 AM
BillDS650's Avatar
had mine done for $80.00 looks nicer. It will reduce the temp of the pipe.
Old Oct 15, 2003 | 12:10 PM
Here in Wisconsin we have alot of abrasive mud and I also think that in time it would wear off.
But if there was some horsepower to be gained I might consider.
Old Oct 15, 2003 | 12:16 PM
ironrod's Avatar
You might consider Nikel plating instead. The heat dissipation properties are very similar, plus nikel is very durable and it plates the inside and out - no more rust. They will blue with the heat, but can easiliy be polished. I did the nikel plate option and l love it.
Old Oct 15, 2003 | 12:35 PM
jaycekarl10's Avatar
On my old quad I did an aluminium coating. I think it was done by heating the aluminum to a super hot temp and blasting it on to the pipe inside and out. It looked good, little discoloration and seemed to hold up real good to sand and rock. It should run about the same as ceramic, but to be khonest, I didn't have to pay for it since it was his first one and I was the guinea pig.
Old Oct 15, 2003 | 01:17 PM
KGB's Avatar
KGB
Good Question. I have always had my pipes done by HPC. Its pretty cheap, lowers the temp of the pipe itself quite a bit, but its not really durable, but then again chrome sucks worse, it peels off alot quicker, Ceramic just dulls, you can polish it back quite a few times before it's gone.
nachop
Feb 14, 2018 06:57 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
Reactant
Jul 27, 2015 07:45 PM
HondaR24
Jul 21, 2015 12:12 PM
