TACHOMETER
Old Nov 28, 2003 | 06:21 PM
MACMC43's Avatar
Default TACHOMETER
I WENT FOR A RIDE TODAY AND NOTICED THAT MY TACH WAS NOT WORKING. THE LIGHT IS ON BUT TACH IS NOT WORKING.IS THERE A FUSE OR SOMETHING THAT WILL MAKE IT WORK AGAIN.IF SO WHERE.THANKS FOR THE HELP.
Old Nov 28, 2003 | 06:36 PM
SANDMAN430's Avatar
Default TACHOMETER
how old is it? i lost one my self.
Old Nov 28, 2003 | 06:42 PM
MACMC43's Avatar
Default TACHOMETER
ITS A 2003. I'M HOPING IT IS A LOOSE CONECTION
Old Nov 28, 2003 | 07:43 PM
Bahazzzz1's Avatar
Default TACHOMETER
There is 3 wires on the back of the tach. A power, ground, and the feed from the coil. If the light is on check the wire going to the coil. If it is ok then it is proberly the tach.
Old Nov 28, 2003 | 07:51 PM
MACMC43's Avatar
Default TACHOMETER
THANKS, I WILL TRY THAT IN THE MORING
Old Nov 28, 2003 | 09:02 PM
RoughRider01's Avatar
Default TACHOMETER
There are two fuses underneath the seat, around by the airbox. Not sure if they have anything to do with the tach but you can check em out and see.
RoughRider01
tyzorg
May 18, 2005 10:08 PM
sparky2001
Nov 30, 2003 03:09 PM
roonds
Feb 11, 2002 04:49 PM
