anyones choke knob come off on there ds650
Old Dec 15, 2003 | 08:47 PM
jaws03's Avatar
Default anyones choke **** come off on there ds650
i have a 04 baja x and my black **** came off the metal part it is still under warrentyt should i bring it in and have them fix it or would i be able to glue it on or what
Old Dec 15, 2003 | 08:53 PM
Jerfinds's Avatar
just put a little super glue on it and stick it back on, if it comes off again, bring it back. I dont know for sure, but is it threaded, if so, just screw it back on with some glue.
Old Dec 15, 2003 | 08:55 PM
sam's Avatar
sam
yes mine has done it to, I just snaped it back in and tried to be more carful the next time. some times it dont feel like its pulling all the out I push it back in and pull it out again sometime does the trick. I feel your pain [img]i/expressions/face-icon-small-smile.gif[/img]
sam
Old Dec 15, 2003 | 09:55 PM
lilnotts's Avatar
mine does quite often, i always meant to try supergluein it
Old Dec 15, 2003 | 10:09 PM
TheOz's Avatar
Ditto with my 04 X. I'll try to glue it also. Superglue? Isn't there a better adhesive for plastic and metal?
Old Dec 15, 2003 | 10:41 PM
BajaIowa's Avatar
If you guys are good with a welder, I would take the carb off and tig weld a little loop or T on the end and it won't pull off again.
Justin
Old Dec 16, 2003 | 12:06 AM
BajaIowa's Avatar
Just a little grove and maybe some adhesive? No knurling or threads.
Justin
Old Dec 16, 2003 | 12:20 AM
lilnotts's Avatar
well i was look at my stock sensor(i'm puttin a oil press. guage on) and wen i pulled back the boot it had some kind of silicon on it, which i plan to put some new stuff on wen i put it back in, does all urs have the silicon on it, like my sensor has never failed(knock on wood)
Old Dec 16, 2003 | 07:27 AM
dsboy650Baja's Avatar
yes i just poped it back on
Old Dec 16, 2003 | 09:49 PM
BajaIowa's Avatar
It needs the silicone to keep the water out. That is why they are so worried about using a pressure washer, it will blow the silicone off.
Justin
