Tranny jumps into nuetral between gears>>
Old Feb 10, 2004 | 01:50 PM
Jetjock16atWork's Avatar
Default Tranny jumps into nuetral between gears>>
guys, this is a problem ive had for years.... doesnt seem to be getting any worse.. .. once in a while.. like 2-3occurances in a 3day weekend at the dunes between gears like 3rd and 4rth.. or whatever.. it will hit a false nuetral.. i have to shift up or down to be back in the previous gear.... any ideas on the problem and how to fix...
thanks
guys
Jetjock16
Old Feb 10, 2004 | 04:24 PM
DSSleuth's Avatar
more than likely the shifting forks. Fix - replace the forks. Have to tear engine all the way down, split cases and change out the forks. Check out the post "broken shifting fork in tranny"
Old Feb 10, 2004 | 06:39 PM
JSsDS's Avatar
Missing gears 2-3 times in a three day weekend isn't too bad. It could just be the oil that you are using or the oil needs to be changed. When I ran regular 10w40 in mine I could only run it 10 hours and it would effect shifting. I use the good stuff (Mobile1-4T) now and I only miss a gear ocasionally. I doubt its your forks, you would have more problems that 2-3 times/weekend.
Old Feb 10, 2004 | 07:15 PM
Maddog419's Avatar
Might just be your spring, return has gotten weak. I did'nt know how an bombardier is but it's normally an easy fix if thats it.
later
Old Feb 10, 2004 | 07:19 PM
jetjock16's Avatar
thanks for the reply's guys, keep the advice coming.. in all honesty i plan on Running it until it fails, but just curious on your guys's experiance.
JJ
Old Feb 10, 2004 | 07:46 PM
jusrlax's Avatar
I have a nearly brand new 2003 DS (10 hours +-). I had the same type of problem happen to me during a dune trip at Glamis last month. It jumped out of gear (and into neutral) maybe three times in four days of hard riding. Dealer was not interested in breaking the cases to see if the shift fork was the problem. They said they had not had even one DS 650 come in with transmission problems. They told me to wait and see if the problem continues.
Old Feb 10, 2004 | 08:30 PM
1BigDSRider's Avatar
I expierenced similar problems with mine last year about this time. I changed the clutch springs and clutches. I found that the metal shims that go between the clutches have a certain way that they go in. This is what a Bombardier tech told me. I arranged them the way he said and I havent had any problems since.
Old Feb 10, 2004 | 10:58 PM
SandyBear's Avatar
dssleuth is dead on right. My dsx is going in for warranty after this weekend to have the shift forks redone. We have seen alot of the bikes with this problem and unfortunately for those of you that are beyond the warranty period, this is the fix. Split the cases and replace the fork and make sure you refer to the manual when re-installing the spacers.
Old Feb 11, 2004 | 08:40 AM
GEARSMOKER's Avatar
mine's the same way, out of one day hard riding it happens maybe twice. annoying yes, but not worth taking out my motor and spliting the case. i guess i'll just deal and do a lot of oil changes.
Old Feb 11, 2004 | 12:40 PM
jusrlax's Avatar
DSX Bear: How did you go about getting your dealer/Bombardier to step up and do the shift fork replacement? Exactly what symptoms was your bike exhibiting? I am close to being in a battle with my dealer over this, and any input/advice would really be appreciated. My six month warranty will be up in May.
