Jetting (Not the same old question)
Old Mar 29, 2004 | 01:23 PM
Camds650's Avatar
Default Jetting (Not the same old question)
I boutht a Dyno Jet kit and there recomendation were way off 175 main clip on 3. The plugs were white so I what to try the MR HP recomendation. The problem is how close is the conversion as far as flow (175 Mikuni main = 186.7 Dynojet).
1. Can I use a Stock needle with a DynoJet (185 jet / Needle in 5th prosition)
2. Or should I run the Dyno Jet needle
Modded End Cap, K&N Filter, Lid on.
Thanks for your help
P.S. elevation close to sea level
Old Mar 29, 2004 | 05:06 PM
Sandaholic's Avatar
I don't think you can run a stock needle with a Dynojet jet, the dynojet needle and jets are designed to work together. They dynojet had stage 1 and stage 3 instructions. I followed the stage 3 instruction and I was jetted right on. I am sea level also with full exhaust and K&N no lid.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
