Mod endcap results
Old May 19, 2004 | 01:52 AM
DSengineer's Avatar
Has been here a long time!
Default Mod endcap results
Dude. You stold my sig icon. Not cool![img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img]
Old May 19, 2004 | 04:39 PM
rldbobcat's Avatar
Sorry man, only cool DS X one I have found so far.
Old May 19, 2004 | 05:23 PM
DSengineer's Avatar
No problem. I figured someone would start using it sooner or later. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 20, 2004 | 12:15 PM
rykid's Avatar
can you take the factory spark arrestor out and leave the stock end cap? if so do you have to change the jets or will it be fine?
Old May 20, 2004 | 01:05 PM
  #15
ChiliCon's Avatar
rykid, that's the first thing I did to my '03 baja. Remove the cap and cut the spark arrestor off as close to the back of the cap as possible, I used a cut of wheel. Depends on how your running but I was way rich when I cut mine off so rejetting for me was cured by gaining flow. Yes you should notice a difference once you get the jetting right.
Old May 20, 2004 | 02:26 PM
  #16
rykid's Avatar
yeh im not to good with all this stuff not up for taking the carb apart haha [img]i/expressions/face-icon-small-sad.gif[/img] i know ill screw something up and ill never be able to ride again
Old May 24, 2004 | 11:15 AM
  #17
cop's Avatar
cop
To get accurate speeds use a GPS.
Old May 25, 2004 | 09:36 AM
  #18
Freez's Avatar
I raced a guy with a weekend with a trail tech speedo. He set it up and tested it against a road bike with a speedo to make sure its in the right ballpark. He could not get more than 85 miles per hour out of his Baja X.
The bike had a Yoshi pipe, Dynojet kit, K&N and bigger intakes to the airbox and 22" tires. Stock gearing and sprockets.
salixair
Nov 3, 2015 08:25 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
