Oh no a jetting question
Old Jun 3, 2004 | 10:09 PM
MrMeaner's Avatar
Default Oh no a jetting question
Ive got a DS with a flatslide(TM) with a clamp-on K&N and I need some help on jetting. Its got a 11.5/1 so I run supreme and it runs fine but if I lug it and gas it hard it misses. Does anyone have a simular setup. Im at sea level. Its got a 40 pilot and a 142.5 main with the clip in the middle. Anyone got any ideas for me. Took acc pump off and didnt help. Its seems nothing helps.
Old Jun 4, 2004 | 12:32 PM
MrMeaner's Avatar
I know everyone gets tired of the jetting questions but its killing me. Any help would be great.
Old Jun 5, 2004 | 04:04 AM
hondabuster's Avatar
What size is the new carb and what was on there. Its possible, when going to a larger dia carb, the velocity of air slows down, and he torque goes with it.
Try pulling the choke on while it experiences the flat spot, and if it gets better, then its too lean.
Try pulling the air box lid for another run, and if its better, then its too rich.
Usually a miss indicates a lean condition. If you are at partial throttle ( less than 3/4 open), try richening up the needle.
Heres an article on jetting and symptoms.
jetting
Old Jun 5, 2004 | 01:57 PM
Eaglecollector's Avatar
When I used to run the TM45 carb in order to eliminate the hesitaion I had to turn the pump nozzle squirter so that it would squirt directly at the needle. This would keep the solid stream of fuel from entering the chamber and break it up to mix with the entering air.
Old Jun 7, 2004 | 04:14 PM
MrMeaner's Avatar
Thanks Ill try that.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
