KMS Dyno sheets and video from Sand Mountain
Old Jun 6, 2004 | 03:42 PM
  #41
DSengineer's Avatar
Has been here a long time!
Default KMS Dyno sheets and video from Sand Mountain
Originally posted by: PureIntimidation
If you go to KMS's website, it says you only get 7-8 lbs of boost and the hp = about 41. If the system used was the same, and used on a stock DS, how did you all get the 11 lbs of boost and 80+ hp?
Just a question as i also am researching some new options after constantly gettin my rear end handed to me.
Kenny
The KMS site also says a stock DS puts out 28HP???? Their dyno figures seem way off for both naturally aspirated and their turbo setup.
Old Jun 6, 2004 | 06:18 PM
  #42
Majorecho's Avatar
Dsengineer,
the website you are refering to is NOT KMS Performances website. I was confused for awhile too but Kelly explained that over a year ago a guy that wanted to be their distributor set up the website and wanted to start offering their kits. The kits were still in the R&D phase and were not ready to be sold, the guy didn't know the difference between a DS650 and an EX400 and there is a lot of data that is incorrect and irrelevent and is pretty much defunct now. That website has no affliation with KMS Performance nor do they sell any Turbo kits- it was a wanna be website.
The official website is under reconstruction and will up and running soon. The link at the beginning of this thread will be part of that website when it reopens. All factual data will be available there.
Old Jun 6, 2004 | 07:29 PM
  #43
Majorecho's Avatar
Scooby,
For some reason the low impedence injectors have burned up some drivers on ECU's. I'll look into a pingel , the more I think about what was going on the more I'm convinced that I was running the injectors dry.
Old Jun 6, 2004 | 10:45 PM
  #44
1BigDSRider's Avatar
The Kms Ds was very impressive.
Old Jun 7, 2004 | 08:28 AM
  #45
PureIntimidation's Avatar
thanx for the info, i will keep checking in with em.
Kenny
Old Jun 7, 2004 | 09:40 AM
  #46
azsandrider's Avatar
How loud is the turbo DS?
We have noise restrictions at the dunes in Ca. I would assume it is fairly quiet compared to the built bikes.
Old Jun 7, 2004 | 12:09 PM
  #47
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Quite enough to run in a hospitol hallway !!!!!!
NOTE:I might have exagerated a tad there [img]i/expressions/face-icon-small-wink.gif[/img] But i think you get the point !!!!
Old Jun 7, 2004 | 01:10 PM
  #48
BillDS650's Avatar
? street bikes that are EFI due the have a fuel pump and where is it located?
Old Jun 7, 2004 | 10:29 PM
  #49
BigDogAZ's Avatar
Yes it has a fuel pump. it is located in the front next to the oil sump
Old Jun 8, 2004 | 04:28 AM
  #50
Sandaholic's Avatar
Can you use an aftermarket cdi such as the Vortex CDI with the KMS EFI kit?
