TM-45 CARB and Hightower
Old Jun 17, 2004 | 02:52 PM
BamaBoy's Avatar
Default TM-45 CARB and Hightower
OK, I am new to the forum. However, I have been reading all of your post for somtime now. I appriciate all of the good Info.
I read a post today that indicated that Hightower was able to fix the hard throttle cable pull on the TM-(HSR) 45 Carb. My question(s) for HighTower is: have you activated the pump and can you share any info on what you have done to lessen this problem
03 Baja, RWR Stage 1
Old Jun 17, 2004 | 03:20 PM
sam's Avatar
sam
I got alot of info from Hightower hes one of the primary guys to go to for the TM45. he is using the pump. I also have the TM45 and am using the thumb w/ pump activated, my pull is very light what I did is I put the softer spring in and tweeked/twisted it to make it firmer then went over to the pump side and took that spring and twisted it a little to make it softer. I also kept the spring in the thumb throttle intact. Hightower I belive uses the firmer sring and twistes it to make it softer. He will fill you in.JM2C
Sam
Old Jun 17, 2004 | 04:04 PM
BamaBoy's Avatar
Thanks for the info Sam. Have you had any problems as a result....
Old Jun 17, 2004 | 04:23 PM
sam's Avatar
sam
the very first time I did it I had it idle high once or twice after choping the throttle while riding . thats when I took a little tenchen out of the pump spring. hasnt hapen since. Its a trial and error thing ,tell you get it where you want it. I do belive Hightower uses the heaver throttle spring and twistes it to make it softer.
Sam
Old Jun 17, 2004 | 04:24 PM
SANDMAN430's Avatar
using the stock throttle cable makes a large difference.
Old Jun 17, 2004 | 04:38 PM
BamaBoy's Avatar
Will the Stock Cable fit the 45
Old Jun 17, 2004 | 06:46 PM
biggerisbetter's Avatar
on the stock throttle cable where it attaches to the carburetor their is long nut the screws on the carb,and also is the adjustment for the cable. take a hacksaw and cut down one side till your through. then take a flat head screw driver place it into the cut line and twist! teh long adjustment nut will crack open like a peanut shell. the cable will now fit into the TM45 cable holder perfectly.
bigger.
Old Jun 17, 2004 | 06:50 PM
BamaBoy's Avatar
Good info... Thanks... So what is the problem with the cable supplied by RWR
Old Jun 17, 2004 | 07:07 PM
Majorecho's Avatar
Bamaboy,
do you have a TM 45 yet? If not you might want to look at the lectron 45 or 48 and do some performance shopping.
Old Jun 17, 2004 | 07:09 PM
BamaBoy's Avatar
yes, It was part of the RWR Stage 1 setup. I have been looking into the lectron carbs
