Mikuni TM (HSR) - 42, 45, 48 Carb Tuning Guides
Old Jun 18, 2004 | 02:07 PM
BamaBoy's Avatar
Default Mikuni TM (HSR) - 42, 45, 48 Carb Tuning Guides
For those of you who would like some really good info on tuning your carb go to the enclosed URL.
http://www.mikunioz.com/hsr_42_and_45_flat.htm
Scroll down the page until You find: To dowload the HSR Tuning Manual as a PDF file click here.
If you will read this information. It will not take you long to realize that tuning a carb is more than simply changing jets. You will begin to understand the different stages of adjustment to get your carb tuned properly.
You can also apply these fundamentals to tuning the stock carb.....
Also, This carb was developed for use on Hi-Perf Harleys, hince (HSR-45). You can readily find parts at your local Harley Dealer
Old Jun 18, 2004 | 03:06 PM
sam's Avatar
sam
I to have found this it is my guide for tuning my 45 as well. its helped me alot to very good info.
Sam
Old Jun 18, 2004 | 05:08 PM
Musthavefn's Avatar
Just what I was looking for. I have a little studdddder when I hit the wooooops at the bottom of the hills that needs to be tuned out.
Thanks for the post
Rob
Old Jun 18, 2004 | 05:12 PM
Musthavefn's Avatar
Is the HRS-45 exactly the same as the TM-45?
Rob
Old Jun 18, 2004 | 05:50 PM
BamaBoy's Avatar
SAME SAME as my son would say!
Old Jun 18, 2004 | 05:51 PM
BamaBoy's Avatar
Rob, How do you like the twist throttle setup
Old Jun 18, 2004 | 06:22 PM
Musthavefn's Avatar
Only way to ride. I hate the thumb lever.
Rob
Old Jun 18, 2004 | 06:26 PM
Musthavefn's Avatar
I need to hold on as much as I can. If the thumbs not griping then you could come loose from the bars when most unexpected.
Aitch
Jul 21, 2015 09:40 PM
maxjung
Jul 13, 2015 05:11 PM
steveo612
Jul 11, 2015 08:35 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
