High compression vs. factory shocks????
Old Jul 12, 2004 | 11:55 AM
crackerJack's Avatar
Default High compression vs. factory shocks????
what differences will i see between the 03 baja normal compression shocks vs the high compression X shocks. I am hoping they are a stiffer ride. Anyone have some good info?
Old Jul 12, 2004 | 12:05 PM
shmee's Avatar
are you racing? if not you probably wont see a diff.
Old Jul 12, 2004 | 12:15 PM
Mainly dunes but some trails. I am getting the kms efi in the next month and the turbo soon after if not the same time. I don't like how my 03 dives into corners and side hills. I have tried adjusting the present shocks and they are to soft still. I was hopine I could pick up an 05 X with the high compression shocks and put the efi and turbo on that and save the money on aftermarket shocks??
Old Jul 12, 2004 | 01:24 PM
sam's Avatar
sam
You might concider a anti- sway bar. some guy run them here maybe they would solve your prob. ?
Sam
Old Jul 12, 2004 | 02:14 PM
anti sway bar??? how does that work???Are the higher compression shocks stiffer???I appreciate the help.
Old Jul 12, 2004 | 03:00 PM
sam's Avatar
sam
try this for help dura blue anti roll bar I dont use one but it sounds like what you might be looking for, click on the word "anti roll bar" on menu in the link, to the right for more detail. 222 also uses them PM him. maybe put a post on sway bar / anti roll bar to pull some other members thoughts.
Sam
Old Jul 12, 2004 | 03:31 PM
thanks for the help.
Old Jul 27, 2004 | 12:35 PM
DuneRider650's Avatar
I ride a little here and there......
i have a 2004 baja x and the high compression shocks on it are easily stiff enough not even set up the hole way and when they are set up the the hole way its just crazy stiff i weigh 210 pounds and i have them at a little over half on the setting and there fine for everything i do including some big air
STLyamwar
Jul 25, 2020 04:44 AM
Cummins Driver
Sep 11, 2019 01:22 PM
manuelrivera
Aug 8, 2015 04:34 PM
JohnnySplat
Aug 6, 2015 12:07 PM
07Redrider400
Jul 25, 2015 05:31 PM
